Have an intermittent problem with the primary and secondary Air gauge going back-and-forth and the red lights coming on and also at the same time outside temperature gauge going crazy and pyrometer gauge going up and down
06 379 gauges going crazy
Discussion in 'Peterbilt Forum' started by Tim barringer, Mar 27, 2016.
Seriously, I'd check the ground to the cab. ( not sure about the air gauges though) -
Thanks I'll give the ground cables a check for corrosion
Is this the same Tim from Concord NC area? Try checking tail lights...I has one back feed....pulled my hair out ...was 07 smart dash truck and gauges were going crazy...
