hello all looking for a little guidance.. its a 07 acert mxs boost under a hard pull will reach about 20 and it sounds like a frigen vacuum under the hood like a loud blowing noise had one bellow leaking has a new cac .. thanks for any help
Sounds like a boost leak. Check all of your CAC hoses, turbo connections & bellows. I've seen a few of the upper turbo's come loose without a lot of soot showing an exhaust leak. Put a wrench on the nuts to be sure. I've also seen the short bellows between the turbo's crack quite a few times.
