100 air-mile logbook exemption
Discussion in 'Trucking Industry Regulations' started by tscottme, Feb 19, 2009.
  1. tscottme
    tscottme Medium Load Member
    484
    Thanks Received:
    371
    Jul 25, 2008
    Nashville, TN
    One thing to keep in mind about the 100 air-mile exemption from requirement to keep a logbook, it has NOTHING to do with miles on your odometer or how many miles you drive. It's called air-miles because it is using the straight-line distance, on a map, from where you report for work and your farthest destination or pick-up. Theoretically, you could drive 300 miles from point A to point B and still meet the other requirements of the logbook exemption.
    Here's an example: Imagine you start work in West Memphis Arkansas and have a run that has you picking up freight in Memphis, TN and returning to West Memphis, AR every day. Those of you who cross between West Memphis, AR and Memphis, TN know this is a very short trip because of the bridge across the Mississippi river between West Memphis and Memphis on Interstate 40. Now suppose that there were no bridge between West Memphis, AR and Memphis, TN. Suppose the nearest bridge or ferry boat to get from one city to the other was 65 miles due south of Memphis/West Memphis. That would mean your dispatch from West Memphis to Memphis would require you to 65 miles south from West Memphis, AR to the bridge, 65 miles north from the bridge to Memphis , TN (total of 130 driving miles) and then re-trace your trip by driving 65 miles from Memphis to the bridge and 65 miles from the bridge to West Memphis. That's a minimum of 260 miles of driving and that mileage total is irrelevant to compliance with the 100 air-mile logbook exemption.
    If you could make that trip and still comply with the 12 hour work limit and other requirements you could use the 100 air-mile exemption. I still run into drivers that think crossing state borders comes into play when considering the 100 air-mile logbook exemption. State borders do not factor into the use/non-use of the logbook exemption.
    As a practical matter it is your boss/company, and not you, that will determine if you can use the logbook exemption. Your company will need to track your work hours and keep these records in order to satisfy the requirements of the 100 air-mile exemption.
    You can use GPS or Google Earth to get an accurate distance measure of the straight-line distance from any 2 points if you are in doubt about the matter. It's true that if your driving distance between A and B is less than 100 miles you can't be beyond the 100 air-mile radius. But, it is not true that if your driving distance is more than 100 miles you are beyond the 100 air-mile radius. And further, remember that the definition of "air-mile" that is applied by the DOT uses "nautical miles" which are longer than the "statute miles" measured by our odometers in the USA. A "nautical mile" is actually 1.15 statute miles so the 100 air-mile rule is actually a 115 statute air-mile rule in one sense. If you are an OTR driver this will likely never apply to you while you are OTR.
    You can look up the other requirement for the 100 air-mile rule under regulation 395.1e1. There is a 150 mile rule for commercial operations that don't require a CDL. I am not discussing those rules.
    Baack, mrjuggalo9er and dieselbear Thank this.
  2. Roadmedic
    Roadmedic Road Train Member
    18,903
    Thanks Received:
    8,812
    Apr 4, 2007
    I would not worry about the drivers who think about the state line issue. I would be more concerned about the DOT that do.
  3. slodsm
    slodsm Light Load Member
    255
    Thanks Received:
    99
    Jan 19, 2008
    Tyler TX
    ^Ditto. I keep a google map of my yard with a big circle around my legal driving area in Tx, Ark, Ok, and La along with the copy of the law and a time sheet.
    Some DOT guys still ask for logs, others know. I myself have never been pulled by the man (knock on wood) so all of my preparations are for nothing at the moment and it's fine with me if it stays that way.
  4. Mike_MD
    Mike_MD Medium Load Member
    352
    Thanks Received:
    235
    Feb 4, 2009
    O-Zone
    tscottme
    Becareful, it's only about 95 miles from Sheboygan, WI to White Cloud, MI; however, the problem is you have to exit the 100 air mile radius to go around the bottom of Lake Michigan or over the bridge at Mackinaw, MI. The only way to do the trip within the 100 air mile radius is via ferry. :biggrin_255:
    Be safe.
  5. muscletruck7379
    muscletruck7379 Light Load Member
    87
    Thanks Received:
    12
    Nov 23, 2008
    scottsbluff, nebraska
    I fit into this catagory, its nice since there is so much running and your in and out of the truck so much it would be tough to track.
    we do however have to keep track of miles that are run when we are in wyoming or south dakota, but isn't that a dot regualtion and not just my company?
  6. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    486
    Thanks Received:
    81
    Nov 28, 2006
    Some where USA
    Thats fuel and highway use tax purposes so they all know how much blood to extract for you broke beaten body at the end of the quarter.
  7. Add a truck driving job review
  8. GasHauler
    5,723
    Thanks Received:
    3,662
    Oct 23, 2005
    Vegas/Jersey
    I'm sorry for being off topic here but I just wanted to welcome Scott here. He's got alot of information and I know he'll be an asset to this group. Nice to see you Scott and nice to see you broke away from the other cr-p.
  9. dieselbear
    dieselbear Road Train Member
    1,796
    Thanks Received:
    2,785
    Oct 18, 2008
    Pumpkin Oval Head Thanks this.
  10. GasHauler
    5,723
    Thanks Received:
    3,662
    Oct 23, 2005
    Vegas/Jersey
  11. dieselbear
    1,796
    Thanks Received:
    2,785
    Oct 18, 2008
    No they are the current standards. You must be seeing the passenger carrying reg. Passenger carrying is still under the old 10 and 15 hr, with 8 hrs off duty/sleeper. I'll repost them for you. They came right of FMCSA's website as well I just looked in the regulation book that was printed October 2008 and they are the same. Try www.fmcsa.dot.gov The intrepretations from the website as well.
    (e)(1)(iii)(A) A property-carrying commercial motor vehicle driver has at least 10 consecutive hours off duty separating each 12 hours on duty;
    (e)(1)(iii)(B) A passenger-carrying commercial motor vehicle driver has at least 8 consecutive hours off duty separating each 12 hours on duty;
    (e)(1)(iv)(A) A property-carrying commercial motor vehicle driver does not exceed 11 hours maximum driving time following 10 consecutive hours off duty; or
    (e)(1)(iv)(B) A passenger-carrying commercial motor vehicle driver does not exceed 10 hours maximum driving time following 8 consecutive hours off duty; and
  • Draft saved Draft deleted
