13 spd shifting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MGASSEL, Jul 4, 2007.
  1. MGASSEL
    MGASSEL Road Train Member
    1,301
    Thanks Received:
    200
    Mar 27, 2007
    Co
    Does anyone have the shifting pattern for the 13spd?
    The company that I am starting with on July 16 uses them I have only driven the 10spd Freightshaker
  2. MGASSEL
    1,301
    Thanks Received:
    200
    Mar 27, 2007
    Co
    sorry I just found the pattern I did not look hard enough before I posted the question.
  3. MGASSEL
    1,301
    Thanks Received:
    200
    Mar 27, 2007
    Co
    I tried to add a pic
  4. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,916
    Thanks Received:
    12,106
    Sep 17, 2006
    WY
    13 is easy, you'll get the hang of it in a few minutes.
    For posting a pic you'll have to host it some where else and then link it over here. If you can't figure it out PM me the link and I'll do it.
  5. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    486
    Thanks Received:
    83
    Nov 28, 2006
    Some where USA
    all most all trans have the same basic H pattern it's how they arrange the gears and the splitters that make the difference. You have to remember you are shifting 1 or 2 or sometimes 3 boxes as we called them in the old days when each one had a stick now they use air to shift part of it. But a basic 10 speed and a 13 pattern are the same the top side is where you get the extra gears. you split each top gear to get the extra gears in it. You will get the hang of it real quick unless you carry allot of real heavy loads you probably want split anything but the top gear anyway until you get comfortable with it then you will split them on the up hill side and the down hill side both. I love a 13 its the best all around transmission there is in my mind.
  6. Wolfgang_KW
    Wolfgang_KW Bobtail Member
    27
    Thanks Received:
    Apr 18, 2007
    New Orleans,Louisiana
    For those who have to see the pattern and cant be told it looks like this.low end (side switch down)R-2-4|-|-|1-3-5High end (side switch up)You split the top 4 useing the front switchR-6/7-10/11| - | - | --8/9-12/13
  7. Burky
    Burky Road Train Member
    1,913
    Thanks Received:
    180
    Apr 30, 2005
    Southwestern Michigan (Lawrence)
    Kindly check the "Storage trailer" section, and you will find a thread on 13 speed shifting.
  8. crazy35752
    crazy35752 Light Load Member
    145
    Thanks Received:
    12
    May 23, 2006
    scottsboro,al
    13 speed is like a 9 speed but you can split the top gears
  • Draft saved Draft deleted
