2000 ISM 280hp engine????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by puffinsmoke, May 22, 2013.
  1. puffinsmoke
    puffinsmoke Bobtail Member
    35
    Thanks Received:
    Jul 21, 2011
    Greensboro, NC
    Looking to buy a 2000 FLD120 with a cummins ISM 280. Don't know much at all about this engine, every bit of info I can get about it will be much appreciated. Reliability? MPG's? Maximum engine miles.....ect
  2. freightlinerman
    freightlinerman Road Train Member
    1,287
    Thanks Received:
    510
    Mar 4, 2011
    Florida
    It's a turd, fuel economy is pretty good, reliability? Maybe 750k to over haul.That's a low HP motor primarily used in buses.
  3. j-dawg
    j-dawg Light Load Member
    164
    Thanks Received:
    41
    Dec 21, 2011
    Oil town, Ab
    From memory those motors can go as high as 450 hp. Keep in mind they are 11L. If it's dual air cleaner, dual stack it should be good to go to 350 as long asyou have a pyro and good maitenance.
  4. puffinsmoke
    35
    Thanks Received:
    Jul 21, 2011
    Greensboro, NC
    The one I'm looking at has around 450k on it be pull a 28ft pup trailer doing local stuff. Will this truck suit me fine?
  5. j-dawg
    164
    Thanks Received:
    41
    Dec 21, 2011
    Oil town, Ab
    Depends how heavy the gross is and how far your expecting to haul, relatively speaking of course. It's not a power/torque motor. It's designed more for mid sized p&d work. It'll work might just be a little slower than the rest. Wasn't that long ago 350hp was big power.
  • Draft saved Draft deleted
