2000 W900L no brake lights on trailer but I have brake lights on tractor!!
Discussion in 'Kenworth Forum' started by Whitey14243, Jul 19, 2014.
  1. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    You have a break in one of the lines going to your alternator. Take them off and make sure there are not a lot of strands of wire broken and make sure you have a good full connection. That will fix the problem.
  3. mitchtazz
    mitchtazz Road Train Member
    1,826
    502
    Sep 6, 2009
    Lake Wales, Fl
    can this be explained a little more in depth?? cause i'm really not grasping the concept of how the alternator will cause the trailer stop lamps and trailer stop lamps only to not work.
  4. Whitey14243
    Whitey14243 Medium Load Member
    359
    97
    Aug 12, 2010
    Moreland, GA
    Replaced turn signal switch and problem was not resolved!! Checked for broken wires going to alternator and all wires are good and were tightly fastened to alternator!!!
  5. KWmech
    KWmech Light Load Member
    141
    40
    Jun 16, 2012
    Check the wiring at the back of the plug on the connector on the truck for the light cord.
  6. mitchtazz
    1,826
    502
    Sep 6, 2009
    Lake Wales, Fl
    i'm not sure what all has been checked, but here's the run down of a fix.. get a multimeter (has to be a multimeter because it will measure amps).
    Start by pulling the hand valve down to activate your brake lights, bungie it if you have to. Then go to your pigtail going into the trailer.. stick the black probe into the top socket (12o'clock position), and the red probe in the bottom 6o'clock position)..
    If you read anything less then 12vdc, then you have an issue. A test light will light with any voltage, but most lights (had this issue with my taillights a couple of months ago) will only work with the proper voltage.
    If you have no power at the end of your pigtail, disconnect it from your truck and probe the prongs there.. This will tell you if the issue is with your pigtail or not.
    If your not getting any voltage there then find a fuse, if the fuse is good, then you need to find the relay... That's pretty much it.. The pigtail for all of the trailer lights run as one chunky solid cable from the front of the cab to the back of the cab.. It's not in a loom like the wires for the truck chassis.
    I also have 20ft of jumper wire that i use to bypass large sections of my truck to narrow down the possible location of a break in a wire.
  7. grizzly
    599
    432
    Aug 27, 2008
    Layton, Ut
    It has to do with the fact that a Kenworth has a separate circuit for the trailer lamps. Had this exact thing happen with my 2000 KW W900L and after chasing gremlins for a long time (trailer relays, turn switch, fuses, ect.) I found that some of the strands in one of the alternator wires were broken. After fixing and crimping a new end on, everything worked fine.
  8. Whitey14243
    359
    97
    Aug 12, 2010
    Moreland, GA
    Just an update: my mechanic found my issue with the trailer brake lights!! There was a metal clamp securing a lot of the wiring harnesses to the firewall and the rubber isolator on the clamp has worn (rotted) away and the wires began rubbing onto the metal clamp and eventually broke the wire with the fuse in half... So after fixing the wire i now have brake lights on my trailer!! Thanks for all the input and help everyone!!
  9. Hype6477
    Hype6477 Light Load Member
    230
    99
    Jun 19, 2015
    Socal
    hey sorry but, I am having the same issue. I have a KW T660 tho where is this wire with a fuse located at? I am wondering if this is a common KW thing.
  10. Ronton
    Ronton Bobtail Member
    Feb 24, 2020
    I had a 99 w900 didn't have trailer brake lights but did have truck brake lights.i knew about the fuses on the firewall but not fire to them. Checked relay and had fire coming in on the signal side but not on the constant power side. Traced the wire to the alternator and it was corroded! Abs wire to the relay also corroded, hopefully I've helped someone because 6 hours of my life are gone now
  11. aussiejosh
    aussiejosh Road Train Member
    4,655
    5,278
    Aug 28, 2009
    Airlie Beach QLd
    Sometimes it can be as simple as a loose/faulty plug which is the first thing I would look for then the next would be there could be a short sometimes in one of the wires on the trailer.
