2001 Volvo Cummins N14 not starting up right away.
Discussion in 'Volvo Forum' started by boneebone, Apr 9, 2013.
  1. boneebone
    boneebone Road Train Member
    2,232
    2,266
    Mar 13, 2009
    I have a N14 that when you turn the key to start it, it used to start within 2 seconds, now it wants to start during the 2 second duration but it lingers like it is starving for fuel or there is air in the line than it starts up. I have a Davco 329 that I replaced the Top and Bottom Collar O-rings, replaced the inlet fuel line Check Valve because I thought it was sucking air. I don't have any fuel leaks. Does this engine have a mechanical or electric fuel pump, does anyone have any ideas what could be causing this issue? Thanks in advance.
  3. jbatmick
    jbatmick Road Train Member
    2,184
    2,441
    Dec 1, 2009
    hastings, Fl
    Some brands of spin-on fuel filters are bad about not sealing against the mounting head.O-ring is not correct. Also is your starter spinning as fast as it used to ? Both of these problems have caused my N-14's to fire up slower.
  4. nasriza
    nasriza Road Train Member
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    If you replaced the check valve I would definately change the fuel filter they originally used to have the fleet guard fs 1000 try that if it doesn't help then go with fleet guard ff105 its a smalle filter also I would say check or change you're timing sensor they're relatively inexpensive now
  5. boneebone
    2,232
    2,266
    Mar 13, 2009
    Thanks, someone else suggested it could be the Timing Actuator, is that the same as the Timing Sensor?
  6. nasriza
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    Maybe but timing actuator is on an isx not an n14 if they meant what I think they meant
  7. boneebone
    2,232
    2,266
    Mar 13, 2009
    yes, my friend has a ISX, but I'll check the Timing Sensor. Thanks.
  8. bravoo67
    bravoo67 Light Load Member
    252
    34
    Mar 15, 2012
    Brooklyn NY
    I would check crankshaft position sensor(somewhere by flywheel).. not sure if N14 has camshaft as well but definitely when one goes bad truck doesnt start right away.. needs to turn couple times more than usual
  9. nasriza
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    It actually has both sensors in one right by the camshaft gear. Now it's like a $30 sensor before it was really expensive
  10. boneebone
    2,232
    2,266
    Mar 13, 2009
    Update: I have been back to my Mechanic twice since I first posted, he cleaned the Check Valve by the ECM ( it had some gunk in there);and it still hard starts, yesterday he took apart the Davco and resealed it and it still hard starts. I asked him about the Crank Sensor and he said No, because it isn't throwing any Codes. He is thinking the Fuel Pump is going bad. Does a bad Crankshaft Sensor need to set a Code because from reading up on this topic, some say yes, some say no? Thanks.
  11. bravoo67
    252
    34
    Mar 15, 2012
    Brooklyn NY
    $30 +30 min of work and you will have piece of mind there
    Have you ever checked fuel pressure?
    On my D12 engine fuel pressure was getting low, it throwed cose but couldnt really tell the difference in truck pulling power and was starting without any problems
