My 2001 W-900B had developed an issue where the headlights will quite randomly and either come right back on or flicker on or off and then come back on. Another driver said he experienced a similar issue with his T-800 and said it was the weather pack connector under the cab get corroded and starts to fail. Anyone else have an issue with?
2001 W-900B headlight issue
Discussion in 'Kenworth Forum' started by lococreeklivestock, Sep 4, 2015.
Also pull your fuse panel back and look for corrosion on the back side. The windshield may have a leak.
brian991219 Thanks this. -
My truck is older. Washernut on the dash switch was loose, controls ground apparently.
Another possible cause is the flex wiring below the hood hinge/s, any place wires flex repeatedly is a likely place for the wiring to crack/break inside the insulation, while having the outward appearance of being in good condition.
Can you hear a circuit breaker cycling when the lights go out? Due to safety regulations, headlights are supposed to be on an auto-reset style circuit breaker rather than a fuse. I have sometimes seen them trip simply because they started getting weak over time. That and the fact that if you like keeping the cab heat aimed at the floor, it can warm up the fuse box and that little extra heat can cause a weak breaker to trip. Either that or you have a ground fault (ie wire rubbed on the frame somewhere). If the breaker is cycling, be sure to replace it as they get weaker each time they cycle on/off.
brian991219 and bubbanbrenda Thank this. -
I could hear the breaker on my 94 and we found a place in the wiring coming from the turn signal grounding on the frame of the steering column. I finally had to disconnect the low beams and reaim the high beams just to get home.
I just started having the same issue on my 00' W900L tonight. It happened once while I was parked at the truck stop messing with it. I switched relays with another one but that didn't help.
My headlight switch was loose so I tightened it up but then they did it again. I will have to try the plugs next....
