2003 columbia no power outlets and no interior lights! help! please
Discussion in 'Freightliner Forum' started by bow2no1, Jan 24, 2012.
  1. bow2no1
    bow2no1 Bobtail Member
    12
    5
    Jan 24, 2012
    maine
    Thanks! i'll check it out
  3. xrtm4290
    xrtm4290 Bobtail Member
    sioux falls south dakota
    have about 20 freightliners depending on the engine there is a wire from starter runs under the engine to fuse box above the left steer tire
    had to redo the wire in the harness to tell lvd that the alt is charging
    had to redo alot of oem wire harness the split loom rubs bare spots in the wiring
  4. burdman_02
    burdman_02 Bobtail Member
    20
    Jan 23, 2012
    Climax, MN
    I have the same problem. Where is the low voltage protection switch located? I can jump power over in the fuse box and get power to everything so it tells me the problem is before the fuse panel on the passengers side dash.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,640
    Oct 11, 2010
    Borispol, Ukraine
    In pass side wall, behind the seat. Use coin to open a small door
  6. burdman_02
    20
    Jan 23, 2012
    Climax, MN
    Ok, I found it and it is flashing a red light. I have restarted the truck several times and still nothing. Is it possible that I have a bad battery/batteries?
  7. bow2no1
    12
    5
    Jan 24, 2012
    maine
    found the problem!!!
    up under the dash behind the blower, there was a in line 50 amp fuse!!!!
    feeding one of the power wires to the fuse box.
    the fuse was NOT on the wiring schematic from freight liner!!
    it is not visible!
    we removed the power wire from the wire wall and chased them, we knew one wire had a break, it did not have continuity from one end to the other.
    i believe the wire is marked on the schematic and on the wire it self (14 B)
    burdman_02 Thanks this.
  8. Pablo-UA
    7,604
    1,640
    Oct 11, 2010
    Borispol, Ukraine
    i see fuse links sometimes.
  9. chazzmania
    chazzmania Bobtail Member
    Detroit, Michigan
    you do know there is a major fuse panel on top of the passenger side of the dash right?
  10. Tony m
    Tony m Bobtail Member
    Need help my truck was running fine , just pull at fly J to. Get scale I parked went inside came back try to start the truck ,it wanted to start ,then all the light went out no light whatsoever ,pleased help
