hello, I have a 2004 freightliner that has no blower motor output, i have found there is a relay in the relay box above the glove box and when checking the relay i have no battery feed to the relay, anyone seen these fuse boxes go bad?
2004 frieghtliner blower motor issue
Discussion in 'Freightliner Forum' started by s53217d, May 10, 2016.
Might be the Low Power shutdown system.
Low power shutdown system? the blower motor is the only unit on the vehicle that is having a issue,
Last 6 of VIN so I can see which SAM Cab is in there and get some pin numbers for you to check.
