This problem started early this week.. I've had this truck for 10k miles now.. I'm not very knowledgeable about repairing diesels.. but I wanna learn.. my engine brake works but cruise control works when it wants. It seems to stop working if I press the brake @ all n comes back on later..
2007 cummins isx cruise control
Discussion in 'International Forum' started by TruckerPete1990, Jun 5, 2015.
Ok, so you are saying after you are done braking and you want to resume it doesn't? I have noticed some Prostars need the resume button hit twice to reengage the cruise, try this. Other than that I would say either the brake switch is stuck, or steering wheel buttons are worn.
Tryed that doesn't work my button is on dash it's a 9400i. Is a brake switch easy to do?
Make sure your brake pedal is slightly sticking. Yes, brake switches are easy, they are just in quick connect fittings. I think it is located behind the dash.
