The hood appears to have moved forward. I can not see anything out of the ordinary up around the hinges
However back when the rubber latches are the fiberglass is wearing a whole from rubbing and the rubber stoppers do not line up with the hood stops. Any ideas ?
Have not run into anything something has broke or moved out of adjustment.
2007 Freightliner hood problem
Discussion in 'Freightliner Forum' started by FLHT, Jul 28, 2015.
Maybe your cab moved backwards, check the cab nounts.
It's doing what it's suppose to, "Freightshake" lol
Update
Nothing broken just a bad batch of glue used on hood to bond panels together.
And Freightliner will not warranty anything.
