2010 international prostar problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dark_Majesty_06, Sep 7, 2009.
  1. Dark_Majesty_06
    Dark_Majesty_06 Heavy Load Member
    930
    Thanks Received:
    205
    Jun 15, 2009
    Poplar bluff, mo
    Hello,
    I'm just starting out in the trucking buisness here. I have been with central refridgerated services and I was unlucky enough to start out with a prostar with 30k on it. Well needless to say within the past two months.. I've been towed four times now.
    First three because of electrical problems international couldn't fix.. Turned out to be a bad ecu... Now I'm broke down in iowa because my bearing in the clutch for the fan went out..
    What I'm woundering is... Has anyone else had this many problems with their star or is this just bad starters luck? I'm really easy on the truck.. No over revs.. No hot rodding...
  2. Heavyd
    Heavyd Road Train Member
    4,241
    Thanks Received:
    1,872
    Feb 4, 2009
    If it has the Maxxforce engine, I'm afraid you are in for a world of headaches! Prostars with Cummins are usually pretty good.
  3. BrainHurtz
    BrainHurtz Light Load Member
    245
    Thanks Received:
    53
    Jun 24, 2008
    Terre Haute, In
    Which ECU? Fan clutches often die prematurely from cycling on and off too rapidly, and just like everything else these days they're controlled by an ECU. So the damage may have been done when you were having ECU problems.
    If you're still having electrical problems it could be a bad ground, things act just as funny with a bad ground as a bad ECU.
    Baack Thanks this.
  4. Dark_Majesty_06
    930
    Thanks Received:
    205
    Jun 15, 2009
    Poplar bluff, mo
    Actually,
    I'm running a cumming. Only problem is.. With me governed as much as I am.. Its a little doggy even under 25000 in the trailer.
    My dash told me on the last breakdown.. That I had a faulty electric ecu. That's when I was heading home down a backroad in arkansas and hit a curve then all the sudden every stich of lighting just went out and never came on again. International told me the ecu going bad had a contributing factor of a bad ground.
    Other than that.. The trucks okay.. But I'd rather be in a 680 volvo. Much more room and I think more dependable.. Our volvos are equiped with cummins as well.
  5. Heavyd
    4,241
    Thanks Received:
    1,872
    Feb 4, 2009
    International has always been famous for allowing 3 feet 11 1/2" of wire between two connections that are 4 feet apart! You would be amazed how tight some of the wiring is tied down! Too many zip-ties, too much tape. It is common to take a turn and then loose something as the cab/frame flexes. The harness stretch to the point where the terminals pull right out of the connector bodies. There were issues with bad grounds next to the body controller. The harnesses that plug into the body controller are tied too tight aswell.
  6. sgreer78
    sgreer78 Light Load Member
    250
    Thanks Received:
    43
    Jul 26, 2008
    St Louis, MO
    Most new trucks have months of bugs to work out. There are too many variables that come into play when you're talking about trucks. They're almost like mass produced RV's. Not many are exactly the same, even from the same fleet. Werner used to spec all their Centuries the same, but every now and then there'd be one with a 13speed and 3.55's instead of the standard Super10 and 3.70's.
  7. Add a truck driving job review
  8. Jakebrake
    Jakebrake Bobtail Member
    40
    Thanks Received:
    10
    May 31, 2009
    I had an '08 Prostar with Cummins. After dealing with it I would never think of buying anything that says International on it or work for a company that had them.
  9. Dark_Majesty_06
    930
    Thanks Received:
    205
    Jun 15, 2009
    Poplar bluff, mo
    i had no idea about all that. i thought i was lucky. guess so in a way. my truck runs 66 instead of 62. i was told that if they were to back it down..it would void the warrent due to having to reprogram the computer. anyone have a problem with thier clutch? my makes the weirdest vibration and thuding sound when you apply the smallest amount of pressure while moving. no sound while its setting still tho.
  10. cat from the valley
    cat from the valley Medium Load Member
    468
    Thanks Received:
    29
    Dec 8, 2008
    jamaica
    does the gear stick move over to the right when u moving off? if so a gearbox mount is gone
  11. Heavyd
    4,241
    Thanks Received:
    1,872
    Feb 4, 2009
    Yes, they are all noisy when you apply just a little pressure. Reprogramming the maximum road speed will not affect your warranty.
  • Draft saved Draft deleted
