Aftermarked DPF should not matter, they just won't cover it. I suspect your DOC is bad and it isn't doing full regens on its own on the highway and it keeps plugging the DPF. Is the dealer following the Aftertreatment symptom based troubleshooting?
2010 prostar maxxforce 13 no power/speed
Discussion in 'International Forum' started by grandpa joe 71, Jul 9, 2016.
Page 5 of 8
What is doc
The DPF is just the filter that collects the soot from the engine. The DOC is another section of the exhaust attached to the inlet of the DPF. The DOC is basically a catalytic converter that is responsible for generating exhaust temps over 1000 degrees during a regen to bake away that collected soot.
So whatever happened would like to know
Heavyd Thanks this. -
I had the same problem. Charge air cooler temp sensor was bad. Easy fix
Team818 Thanks this. -
Page 5 of 8
