Hello,
I have a 2012 Cascadia with a DD15 Engine, about 460k miles. Both Check Engine and Maintenance Lights are on. I am getting 2 Active Faults. EEC 061 SPN004364 01, and EEC 061 SPN004364 18. I know this has something to do with the NOx Conversion System. But what does this mean in regular English, as I am unfamiliar with the new DEF systems.
2012 Freightliner Cascadia - Check Engine and Maintenance Light
Discussion in 'Freightliner Forum' started by Singh115, Jun 28, 2015.
Singh115 Thanks this. -
Cheaper in the long run to just replace the DEF filter. 3-4 hour job, instead of over a day to bake and replace.
Thank you all for your replies. The DEF filter for the truck was changed at 390k.
The parts number for epa10 dd15 dpf's is RA6804910894. Google it or call to the dealer to see how much is the cost. There are two dpf's on the truck. Cleaning costs $450 for two dpf's at Detroit's official dealers. They use FSX Pneumocleaning instead of old style bake and blow. The cleaning process takes max 2 hours. Also you need to buy 2 clump - seal kits about $90 each of them. The labor is about 3-4 hours at dealer cost. I have invoices and I have posted it so you can see it.Attached Files:
Thanks all. Turns out it was a bad NOx sensor.
