Does anyone know how to shut off the blasted beeping? I had it in the dealer today. The boss wants me to limp it home. Not my truck and I don't care if it blows up, but if I don't get this beeping to stop I'm gonna end up sucking the business end of my 40 in the next 800 miles. It's already derated but I can maintain 65mph with it. Please tell me there is a fuse because I can't get to it under he dash. Seems to be buried.
2012 ProStar Stop Engine alarm
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bukrub, Oct 26, 2016.
Those are usually mounted on the circuit board for the instrument cluster.
What is causing the alarm that won't kill it in 800miles? -
It will most likely be dead long before I get home. It's showing several active codes. We had the DPF baked last week. It is now showing EGR, ETV and ETP, as well as a 2 of 3 suet level on the DPF since it won't regen.
That will derate to 55mph and about 150hp soon, then 5mph on the next startup.
Pull the two breakers for the cluster from the fuse panel in front of the passenger seat. One is F2-G and I can't remember the other one, but they are labeled. This kills the whole cluster so the speedo is dead too, but if you have a gps you can still watch your speed, but at least the beeping will stop.
Bukrub Thanks this. -
I didn't get a notification that you replied, but I did make it home at 60 MPH. The #### beeping is still in my head. Maybe by Monday it will be gone. Thanks for the input.
Heavyd Thanks this. -
Heavyd Thanks this.
