255 70R 22.5 tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Nov 6, 2011.
  1. Oscar the KW
    Oscar the KW Trucker Forum STAFF Staff Member
    9,169
    Thanks Received:
    12,716
    May 19, 2011
    What brand of tires are you guys running in a 255 70R 22.5. And what air pressure do you run them at. Got some cheap china tires on my stepdeck this summer and noticed today one of the sidewalls has a split already. I run these at 110 psi.
  2. 25(2)+2
    13,047
    Thanks Received:
    11,286
    Sep 18, 2006
    the road less travelled
    From what I have seen, Hankook is good.
    110 to 120 psi is what our company runs, and no, they don't buy Hankook, the last 2 new trailers they bought came equipped with them, and they lasted better than most.
    Sometimes, you have to take what they got or what they bring you.
  3. kelgar50
    kelgar50 Light Load Member
    293
    Thanks Received:
    121
    Feb 1, 2007
    Bakersfield,CA
    I ran Yokohama tires on my step when I had it they wore really even and last good. As for the tire psi I would run 100 psi.
  4. bonder45
    bonder45 Light Load Member
    187
    Thanks Received:
    41
    Oct 2, 2011
    Edmonton, Alberta
    .....any recommendations for this size tire on the drives of a tractor?
    For some reason the truck I was running today has these baby tires on it :\
  5. Oscar the KW
    9,169
    Thanks Received:
    12,716
    May 19, 2011
    Anyone run a kelly tire in that size for a trailer? I have kelly kda's on my drives and they are wearing really good.
  6. Mack427
    Mack427 Light Load Member
    272
    Thanks Received:
    60
    Jan 22, 2009
    Kelly Springfield is a good tire its the comes of the same line as a Goodyear, however, Goodyear has stopped making the brand completely a couple of years ago, so whats out there is old inventory
    Oscar the KW Thanks this.
  7. LBZ
    LBZ Road Train Member
    1,522
    Thanks Received:
    782
    Oct 22, 2008
    Road to Nowhere, IL
    Check BF Goodrich ST 230. Had those on a car trailer & never had a issue. Probably won' get quite the life out of them vs a Michelin, but when I checked prices it was around $100 each difference.
    Also called half a dozen tire shops checking prices on these, big difference there too. Check with Bauer Bilt in the midwest, they were pretty competetive.
  8. 25(2)+2
    13,047
    Thanks Received:
    11,286
    Sep 18, 2006
    How accurate is your speedometer and odometer? There are 2 22.5 low pro sizes used as drives and steers and therefore on trailers; 285/80R22.5, and 295/75R22.5.
    They have the same circumference and load ratings. You might see either size substituted for the other.
  9. BAYOU
    BAYOU Road Train Member
    2,889
    Thanks Received:
    1,547
    Sep 23, 2010
    Beaumont,Tx
    I run firestone fs560 on my stepdecks with 110psi have 60,000 miles on them still look good they run me about $375 a tire monted W/fet out the door
    YOU GET WHAT YOU PAY FOR!!!
  10. fortycalglock
    fortycalglock Road Train Member
    5,430
    Thanks Received:
    4,784
    Jun 25, 2011
    Tourist Town, FL
    I want to say the carhaulers that park in the lot with me with 255's on their drives run Yokohama's. Talk with them as they are the main ones that run them on drives and steers.
    As far as the OP, I run Bridgestone 250ed on my step. Great tire and we get them pretty cheap, so it makes it a winner in my book.
  • Draft saved Draft deleted
