3406B engine oil capacity?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by coadman, Jan 1, 2009.
  1. coadman
    coadman Light Load Member
    153
    Thanks Received:
    26
    Dec 20, 2008
    Freeport,Kansas
    We bought an old 1988 Pete with a Cat 3406B motor in it, so we have it in our shop now to change all the fluids. Only problem, I don't know how much oil this thing holds, can anyone help me out?
    thanks,
    coadman
  2. Les2
    Les2 Road Train Member
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    kicked back in my lazyboy...
    If you popped both plugs it should take 10 gallons but you might want to check it at 9.
    coadman Thanks this.
  3. lastgoodusername
    lastgoodusername Medium Load Member
    384
    Thanks Received:
    125
    Dec 18, 2008
    takes 10 gallons , check the dipstick after you start the engine and let the oil settle back down. if it is not on the mark , make a new mark. believe it or not , the dipstick may not be right. if you buy a new one , from the cat house, they have to be "calibrated". johnny
  4. coadman
    153
    Thanks Received:
    26
    Dec 20, 2008
    Freeport,Kansas
    Put in 9 and checked it,,,,just a little on the low side, so added the other gallon, and it was just right,,,,so 10 it is,,,,thanks guys!
    Ecnal regnew Thanks this.
  • Draft saved Draft deleted
