Ive read high and low on what resistor to use and what wires to put it in without a strait answer. Seems like nobody is really sure of what actually works. Have tried the 450ohm between the white with the sensor end white wire soldered to the black wire and the othed end of the resistor soldered to the white and black with the orange wire cut witout any noticable change. Does anyone else have any ideas?? Thanks in advance
3406E 3 wire fuel temp mod
Discussion in 'Trucks [ Eighteen Wheelers ]' started by E model Cat man, Sep 28, 2016.
once fuel warms up mod loses it effectiveness if I'm not mistaken .. at best it's only a minor power gain iirc. PS don't cut your harness get a seperate plug that you modify and can unhook if needed
Its about a 25-35 hp gain IF you can keep your fuel on the cool side.
magoo68 Thanks this. -
Yeah i know how that part works...i have a fuel cooler in the return side. Soooo where does the resistor go??? Thats the answer im looking for.
