I have a 70 bbl tank on the back of a 359 when its loaded its causing the front end to bottom out very easy. What would be the best way to fix it, add a leaf to each side or add a air bag in between the leaf and the frame?
359 front suspension troubles
Discussion in 'Peterbilt Forum' started by Diamond_S, May 19, 2015.
If you can have a new set of springs put on they should have new bushings allready in them and should ride much better for about what you would spent on add on air bags?
I have seen lots with airbags installed. Gives you the option for a smooth ride with no load or put pressure to them with a big load.
