I have a 600 CAT w/1.3 million, when I shift (usually in the high side) engine will flutter badly, no matter what rpm, this lasts for approximately 5-6 seconds then smooths out, but it's getting worse. Only does this under a heavy load and when it's hot out. When it's cooler at night it does it but not bad. I put new injectors at 1 million,kenworth run an injector test & found nothing wrong. Any suggestions?
600 CAT, engine flutter.
Discussion in 'Kenworth Forum' started by Ed Patrick, Aug 29, 2015.
Check fuel pressure,fuel lines,tank vents.
Start with the simple stuff first.
When was the last time the fuel filter was changed?
Which model cat E-C15-accert? -
Yah I would check fuel filters I had to in the beginning of getting my truck change my fuel filters like every 2k miles I was using bad fuel . Didn't know it till a mechanic road with me and told me change fuel filters these cats love there clean fuel filters
I change the fuel filters and the check valve in the filter housings, no difference. I do get fuel in the same places every week, so I'll switch up on that and check the filters. Thank you.
It's a C15, non acert. Kenworth did a fuel pressure check, determined there was a bad fuel line and changed it. It done good for about a week (2500 miles), then started fluttering again. They ran another check and also an injector cut out test, come up with nothing.
KB3MMX Thanks this.
