I have a fld classic 2000 with a sanden compressor and i have freon coming out relief valve on back of compressor. Old one lock up so I replace dryer front expansion valve and compressor. Before it lock up it was working fine now I'm clueless
Ac problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Xavier jackson, May 28, 2016.
Its blowing out the back because thr pressure is too high. Did you replace the condensor at the same time? Did you have the system vacced and recharged? Orrrr Did you simply replace the compressor and try to charge it yourself....
I'm guilty of the last.... shame on me. -
Does the fan cycle on and off?
Your fan should cycle on and off with head pressure. Could be bad high pressure switch,fan switch.
Make sure you hooked the lines to the right ports on the compressor. Not trying to be funny,I've seen it happen
lilillill Thanks this.
