Its a vnl 610, and has not worked since I bought it. I haven't started diagnosing button solenoid etc yet, just wondering where the horn is mounted? Thanks in advance.
air horn no worky
Discussion in 'Volvo Forum' started by Marshall Lucky, May 29, 2015.
Depends of the year of the truck ? Two possibility
Under the cab LH side for end 2002 and UP
In the RH front frame rail for begining 2002 and ealier.
Hope this can help.
Ben -
remove the steering wheel cover. BE CAREFUL. Don't deploy the AirBag. Might want to disconnect the batteries.. There are pieces to the horn under that that get bent. I had that problem when I first bought my truck. You simply need bend those prongs up a little and the horn should work. At least, that was my problem.
city horn or air horn.
