Best Fuel Mileage?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NSteinbecker, Nov 1, 2011.
  1. NSteinbecker
    NSteinbecker Bobtail Member
    35
    Thanks Received:
    Oct 19, 2011
    Georgia/Colorado
    Anyone know which semi gets the best fuel mileage?
  2. Pablo-UA
    Pablo-UA Road Train Member
    7,458
    Thanks Received:
    1,422
    Oct 11, 2010
    Borispol, Ukraine
    this is equation with too many variable values, and it is a quation of high mathematics....
    123456, grizzly and NSteinbecker Thank this.
  3. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    Thanks Received:
    45
    Oct 18, 2010
    Detroit, MI
    Anything mechanical rises no higher than #2 on the list of important factors when considering fuel mileage.
    The driver is #1 on that list. How the equipment is driven & maintained has the biggest impact, positive or negative.
    NSteinbecker and The Challenger Thank this.
  4. Frenzy
    Frenzy Medium Load Member
    331
    Thanks Received:
    178
    Mar 24, 2008
    Seattle, WA
    The one I drive.
    (Dice1's might be better thou)
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    Thanks Received:
    629
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you are looking at the a group of engines and want to know which one has the best fuel mileage there are EPA stickers on all engines. It has a section that has the number of MM3 of fuel it takes to make the rated HP. The lower the number the better. Driver, rolling resistance, aerodynamics, road conditions, weather, all have an effect.
    NSteinbecker Thanks this.
  6. Dice1
    Dice1 Road Train Member
    1,315
    Thanks Received:
    589
    Jul 1, 2011
    Bessemer City, NC
    Got 14 mpg bobtailing but never that much with a trailer.
  7. Add a truck driving job review
  8. rollin coal
    rollin coal Road Train Member
    7,211
    Thanks Received:
    7,747
    Mar 29, 2008
    TN
    Read somewhere that driver habits are the biggest impact on economy by as much as 30% same truck, same conditions 1 driver with good habits another with poor. Maintain it, and drive it right.
  9. Scania man
    Scania man Road Train Member
    2,199
    Thanks Received:
    473
    Jul 1, 2011
    Saskatchewan
    I'm not sure if Ure asking this because you're gonna buy a new truck if you are here is something worth considering : I've always driven 6*2 or 4*2 tractors, I know the scania r620 6*2 will do 8 - 10 mpg depending on terrain, weight etc, I've recently driven a 6*4 double drive scania r620 and it does 7-8 mpg max, that's a big difference, dice had a great thread and it dealt alot with frictional losses and these figures represent the findings on that thread, so it might be worth considering opting for a 6*2 lift axle instead of a 6*4 as it normally means 1-2 mpg because you will only have one diff instead of three and less shafts bearings etc,
  10. lostNfound
    lostNfound Road Train Member
    3,513
    Thanks Received:
    2,206
    Jun 28, 2007
    Home of the Stampede
    I am consistently getting 15%-20% better mileage than 2 identically spec'd trucks on the same haul with the same load. I run the same speeds (even slightly faster). The biggest difference is that I keep the engine RPM in the optimum work zone, especially when climbing hills.
    3gCowboy and NSteinbecker Thank this.
  11. Scania man
    2,199
    Thanks Received:
    473
    Jul 1, 2011
    Saskatchewan
    That's not surprising, a good consciencous driver can make a massive difference ! Just looks like you know how to drive
  • Draft saved Draft deleted
