Best semi truck for off road oil fields
Discussion in 'Ask An Owner Operator' started by K_man, Dec 7, 2011.
  1. K_man
    K_man Bobtail Member
    12
    Thanks Received:
    5
    Nov 18, 2011
    Central, MN
    I'm having a little debate with my buddy about what the best truck would be for off road use in the oil fields of ND.
    What's your opinion on the best truck for oil field use?
  2. haulhand
    haulhand Road Train Member
    2,025
    Thanks Received:
    1,705
    Feb 6, 2008
    Rock Springs, Wyoming/Dickinson, ND
    It all depends what your going to do with it. Just general hauling like water or sand then a KW T800 is my favorite at least 475 HP 13 or 18 speed and just 40000 lbs rears at 3.90 ratio. Now if your going to use it as a winch tractor still a T800 but with 46k rears at 4.10 or lower and only an 18 spd. If its a bedtruck your wanting then the only way to go is a C500 with a 475 horse 18 and a 2 with either Sisu or Clark planets about 385" wheelbase and 3 winches on it. I guess what I'm saying is that I don't like to run much but KW's in the patch the rest just don't hold up to the abuse.
    - Sent from my iPhone using Tapatalk
    volvodriver01 Thanks this.
  3. V8-MACK
    V8-MACK Light Load Member
    249
    Thanks Received:
    75
    Aug 18, 2009
    R model Mack, with Mack engine,trans,and rear end, with camel back suspension and a double frame is the toughest truck ever made. I pulled the strongest horizontal drill rig off road,super tankers 290k, all over the great USA,some jobs where quite a few miles off road. The SuperLiner with the same specs, but with the e-9 V-8, is the King of all trucks.
    SHC and Mommas_money_maker Thank this.
  4. BanditTrucker
    BanditTrucker Light Load Member
    256
    Thanks Received:
    60
    Nov 24, 2011
    KS
    i would say the best trucks for off-road are the kw t-800 and mack ch613.
  5. 2hellandback
    2hellandback Heavy Load Member
    978
    Thanks Received:
    221
    Dec 19, 2007
    Blackfoot Idaho
    Both above trucks will work, full lockers would be nice.Myself i prefer a sleeper but many will disagree on a sleeper.
    And my t-600 did fine hauling water sand and cement but most will disagree on that toooooo.
    SHC Thanks this.
  6. REXHOUND
    REXHOUND Bobtail Member
    48
    Thanks Received:
    Dec 16, 2011
    Uranus
    mack superliner, E9 v8
  7. Add a truck driving job review
  8. REXHOUND
    48
    Thanks Received:
    Dec 16, 2011
    Uranus
    or autocar, 8v92... leaks mean love:biggrin_255:
  9. ironmule
    ironmule Light Load Member
    161
    Thanks Received:
    52
    Nov 4, 2011
    PNW
    Whats a good wheel base for truckin sand or water or bellydump? drop axle common... Thanks,IM
  10. haulhand
    2,025
    Thanks Received:
    1,705
    Feb 6, 2008
    Any wheelbase will work depends sleeper or day cab. There's guys doing it in 190" day cabs which are real nice on a tight lease but ride like hell, then there's guys with a 320" Pete looks good rides real smooth but is a pain in the ### on any lease. Perfect for my pnuematic trucks is 244" rides decent enough room for a blower and is fairly easy to get around on the leases, I do have trucks running at 265" and 270" and they're ok but can be a pain.
    volvodriver01 and ironmule Thank this.
  11. ironmule
    161
    Thanks Received:
    52
    Nov 4, 2011
    PNW
    Air bad susp.hold up or roads beat em and break em what susp. do you
    recommend? Thanks,I.M>
  • Draft saved Draft deleted
