I have a 2007 Columbia and the blower went out. I opened up the compartment under the fuse box looking for the blower resistor and found a mess of harnesses. Is the resistor located in that area?
On a Columbia, the resistor is built into the blower motor. Check to see if fuse is blown. If it is, replace blower motor. Also change check/change cab filter. Good luck.
