Brake adjustment
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Workinprogress1001, Jul 22, 2013.
  1. Workinprogress1001
    Workinprogress1001 Bobtail Member
    36
    Thanks Received:
    Mar 31, 2013
    Someone recently told me that to adjust brakes on your truck you adjust the steers and the first drive axle the yellow valve out. Is this true? Ive always pushed it in then adjusted on all axles
  2. rocknroll81
    rocknroll81 Road Train Member
    1,223
    Thanks Received:
    764
    Sep 29, 2010
    West Allis Wi.
    The brakes have to be released to adjust them, if the yellow button / tractor parking brake is out the brakes are then applied and against the drums, how could then adjust the brakes, unless I am not under standing what your saying.......
    S M D Thanks this.
  3. fuzzeymateo
    fuzzeymateo Heavy Load Member
    737
    Thanks Received:
    709
    May 20, 2013
    AZ
    A steering axle does not have a spring brake chamber. It is a service brake chamber so regardless if the parking brake ("yellow valve") is set, the wheels will turn freely. Yes, to adjust spring brakes (other axles) you must release them before you adjust them. This is of course if you have manual slack adjusters which you probably do not. They are probably automatic slack adjusters which should not be adjusted but rather replaced if they are out of adjustment.
    Workinprogress1001 Thanks this.
  4. rocknroll81
    1,223
    Thanks Received:
    764
    Sep 29, 2010
    West Allis Wi.
    Yes, I should have stated that as the maxi or service brake are on one axle, but I tried to make a simple statement...
    fuzzeymateo Thanks this.
  5. Workinprogress1001
    36
    Thanks Received:
    Mar 31, 2013
    Thanks for the info.
  • Draft saved Draft deleted
