C-15 Cat Engine Problems.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dave_0755, Nov 4, 2010.
  1. TA63
    TA63 Bobtail Member
    48
    Thanks Received:
    Oct 28, 2010
    How much manifold pressure should a 550 Acert run? During cooler weather, it will hit 50psi under heavy load.
  2. DL550CAT
    DL550CAT Road Train Member
    1,029
    Thanks Received:
    736
    Oct 18, 2009
    Waynesburg, Pa
    If you have to borrow the money to get a PDI tune its worth paying the interest on it. It will pay for itself in less than 6 months.
  3. DL550CAT
    1,029
    Thanks Received:
    736
    Oct 18, 2009
    Waynesburg, Pa
    I think stock mine would do about 52 on a cool day. It does a tad more than that now:biggrin_25525:
  4. vinnie_
    vinnie_ Bobtail Member
    25
    Thanks Received:
    Oct 2, 2010
    nh
    dave_0775 wash your air to air and radator out inside and out side also the thermostat housings wear out and they will turn side ways in the casting and or slide with in the oring aka gasket id check all this first more time than money!!!!!!!!!!!!
  5. ridefree4life
    ridefree4life Bobtail Member
    Thanks Received:
    Jan 15, 2011
    niagara falls,ny
    i am looking at a 04 cornbinder it has a c15 475 set @550 with 600k on it ,it has the twin turbo ,engine ser.# bsx07122 ,with 1850 lb-ft @1200rpms..has a 13spd.with 3.42 rears.sitting on 11r24.5 meats..previous owner said water pump was the only thing done to it..would like a little in put on making the purchace of this truck.all my experience is with 60 series detroits your input would be great thanks
  6. Jfaulk99
    Jfaulk99 Road Train Member
    2,918
    Thanks Received:
    1,586
    May 16, 2009
    Couch
    That's all I've replaced on mine (06' MXS). Great motor, especially with a stage 1 PDI tune. Would not hesitate to buy another, mine is on 3.36's with a 13spd. 24.5's.
  7. T800
    T800 Light Load Member
    64
    Thanks Received:
    Mar 23, 2010
    Calgary Alberta
    I was told that the rule of thumb was 47-50 psi for a 475hp, 50-55 psi for a 550hp and 60-65 for a 600hp mine will hit 75 psi on a brisk Canada winter day.
  8. DL550CAT
    1,029
    Thanks Received:
    736
    Oct 18, 2009
    Waynesburg, Pa
    I have a ACERT would buy another I love it. If you get it put the PDI tune in. It is worth it at twice the price! You will need to change your driving habits a ACERT does not run like the 60 series.
  9. 3500DRW
    3500DRW Light Load Member
    58
    Thanks Received:
    10
    Dec 12, 2010
    Katy TX
    So what's the story on dave 0755's truck. Why is his truck over heating. Never mind when the fan or buzzer should come on, help the man fix his truck!!!!
  10. oneshot
    oneshot Medium Load Member
    627
    Thanks Received:
    240
    Feb 28, 2009
    mississippi
    Dont u think when the fan and buzzer should come on is important?The ECM controls both and on the Acert it is 217 and 228.He said his fan comes on at 235 and normally runs at 200.Sounds like his gauge is wrong to start with.Then maybe a good air to air and radiator cleaning would be a good cheapway to start.But he has'nt updated in a while so maybe it's fixed.
  • Draft saved Draft deleted
