CAPITAL $$$$$$
Discussion in 'Ask An Owner Operator' started by jbear74, Jul 7, 2015.
Mods, can you make the DY thread a sticky plz??
this topic is readily discussed in the forums; use the search function. And, go read everything you can at OOIDA, bottom line, there's no cookie cutter answer to this one.
jbear74 Thanks this. -
I think Dune-T was referring to this thread from DoubleYellow:
Double Yellow's Company Driver to Independent Thread
Another good thread to read is:
So you want to "own" your own company
Like just_the stated, OOIDA site will become your best friend.double yellow Thanks this. -
$10,458.07
Thought it was 10,458.47 don't forget tcarry the 4
spyder7723 Thanks this. -
Op, are you starting you figure out that you're not going to make many friends with so many different threads asking basic brain dead questions?
If you put in the effort to do some of your own research, even if it's only using the forum search feature, your questions will then be more educated, and much more likely to get constructive responses.
A little perspective: right now your questions on this forum are sorta like if I was to go to a forum for nfl players and post "I want to be a super bowl winning quarterback, how can I do this?"Last edited: Jul 7, 2015
