cat 3406b -fuel transfer pump problems?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dairyman, Dec 21, 2010.
  1. dairyman
    dairyman <b> Hopper Thread Greeter</b>
    1,218
    Thanks Received:
    921
    Oct 31, 2009
    Ky.,wait'n in line
    Just wondering if any of you folks that still run the 'ole mechanical's can tell me what the symptoms are when the transfer pump that's under the injection pump starts going bad? My secondary filter is loosing prime. Filters are all good,no line blockage,and as best i can tell,i'm not having a line collapse problem.
    Any thoughts will be greatly appreciated. :biggrin_25514:
  2. Brickhauler
    Brickhauler Medium Load Member
    407
    Thanks Received:
    130
    Oct 1, 2008
    Elizabeth CO
    There are a couple of check valves in the hand primer pump on the top of the secondary filter, you might look there. Also if the primer pump plunger is not screwed down tight into the base you can suck air there.
    I had the transfer pump go out once and the truck would start and run fine, go through all the gears on the low side but after you got up into the higher gears it would just act like it was running out of fuel.
    dairyman Thanks this.
  3. dairyman
    1,218
    Thanks Received:
    921
    Oct 31, 2009
    Ky.,wait'n in line
    Thanks Brickhauler,i put a new hand primer on after it lost prime the first time a few days ago so i don't think it's the hand primer now since it did it again today,but that was my first thought too:biggrin_25525:. The old girl starts fine at first start up,then acts just like its gelling up, so i shut 'er down. After this happens though,i can pump(hand prime) it back up,and it will run fine:biggrin_25526:,so its got me a little puzzled.I hauled a full load of corn today,short trip,and it ran fine,no miss or sputter,maybe a tad sluggish,but still fairly strong. I just don't want to damage anything with injection pump(possibly starving it for lack of fuel) if transfer pump is going bad,ya know. So you didn't have any prob's with yours acting like it was sorta gelling after 20 seconds from start up when your transfer pump went bad,or did it just have low power on the high side?
    Thanks for your post,any more thoughts?
  4. Brickhauler
    407
    Thanks Received:
    130
    Oct 1, 2008
    Elizabeth CO
    When mine went bad, the truck ran great from Denver to Chicago. On the way back it started acting up. First I thought it was filters. We then decided the fuel line from the tank was bad. I wound up buying the pump at Cat in DES Moines and putting it on in the parking lot. It ran like a new truck after that. I think there is a test port on top of the secondary filter housing. Maybe you can plumb a gauge in there and check the pressure there while you drive it. I don't remember for sure but I think it's supposed to run around 50-60 psi
  5. Les2
    Les2 Road Train Member
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    kicked back in my lazyboy...
    Did you just change filters and this started to happen? If so, put another set on, but keep the old ones. Years ago I got a bad fuel/water seperator filter that was letting fuel drain back into the tanks. It was only a problem when I shut the truck off.
    Put a gauge on it and it will tell you if its the transfer pump.
    If when you let the truck idle for some time, you take off and it dies, its most likely the transfer pump.
  6. dairyman
    1,218
    Thanks Received:
    921
    Oct 31, 2009
    Ky.,wait'n in line
    Thanks Les2,i was searching for you and ynot last night feverishly:biggrin_25524:,i knew you'd come to the rescue:biggrin_25514:.I had to take 53,000lbs. of corn to Gargill in Cincy early this morning and i was worried about possibly starving the big pump if i was having a transfer pump failure. I had just changed both filters and oil too,so thats a possibility because i used a Napa secondary that i had been keeping in the cab for a spare,and the dang thing was probably 3 years old. I always use a Cat secondary with a LubeFinder,Wix,or Napa on the primary but i needed to change everything that day and i was out of
    Cat secondarys,i have 2 new ones in the shop now,though:biggrin_25525:. Started great this morning and ran good up and back loaded both ways,so maybe your right,THAT would be nice if all it turned out to be was just a bad filter letting it loose prime:yes2557:.I'm gona put the pressure gauge to 'er this weekend if it does act up before then. I'll let ya'll know as soon as i get done.
    Thanks again for your thoughts!
    Les2 Thanks this.
  7. Les2
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    Give me a call if you need any help.
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,236
    Thanks Received:
    484
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    If you are starving the injection pump of fuel you will know it, when mine went out on my GMC it would miss on at least 2 cylinders under a hard pull.
  9. dairyman
    1,218
    Thanks Received:
    921
    Oct 31, 2009
    Ky.,wait'n in line
    Thanks SmokinCAT,that is kinda what the old girl sounds like when i am in a hard pull.Do you remember loosing prime when you shut 'er down,mine runs ok after i hand prime it,but as soon as i shut 'er back down,it will loose prime again?
  10. tweaker
    tweaker Bobtail Member
    29
    Thanks Received:
    Dec 19, 2010
    sidney,ne
    just a heads up if you run a fass it pushes so much fuel filters get plugged quick,napa 1202,or a fs 1010,and on the water side make sure it doesnt have a filter ellement it will fail.
    best thing ive seen is a rail pressure gauge closer to the head,some filters can crush brand new ,ohh and fleet gaurd just moved to mexico.
  • Draft saved Draft deleted
