CAT C-16 out of frame rebuild turbo question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NFDDJS, Jul 14, 2012.
  1. NFDDJS
    NFDDJS Light Load Member
    267
    37
    Jul 8, 2012
    New Hampshire
    So I am getting with the C-16 in my glider. Should have the core motor some time next week. I am not sure if I want to go with the turbo that Cat has when this is getting rebuild. Do any of you recommend a different turbo that will last longer and spool faster?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,723
    Jan 30, 2010
    keep stroking.
    if your getting anykind of warrenty you might not have a choice.
  4. BobbyTTour
    BobbyTTour Light Load Member
    83
    24
    Nov 30, 2010
    Spring Hill, TN
    Mr. Haney can build a turbo for you that will be a non-waste gated turbo that will flow better than the stock Cat turbo and will lower your EGTs for the stock 600 setup. He can also build you a bigger turbo, flash your ECM, and tell you what parts to put in it for anything from mild to wild. It's all up to you and what you want to do.
    Mr. Haney Thanks this.
  5. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    I talked to my dealer and I was told that they will let me put his turbo and ECM in the truck and will cover it. I guess they have a bunch of guys running the stuff and said there will be no warranty issues if something does break... Looks like stage 1 ECM and a turbo for me soon...
  6. Cat sdp
    Cat sdp . .
    19,884
    64,245
    Apr 8, 2012
    Orion's Belt
    Did Milton or the ws dealer say that ?
  7. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    WS dealer said that they will cover it. They said that are Cat OEM dealer (?) so they don't deal with Milton for warranty stuff just parts. Not sure how that works but that is what I was told.
    Cat sdp Thanks this.
  8. Superhauler
    12,209
    100,723
    Jan 30, 2010
    keep stroking.
    thats great. but get it in writing period!
  9. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    Yeah that is for sure
  10. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    Got it in writing but no go on the turbo, have to keep the cat turbo but they put in writing that they will warranty it with a PDI ECM.
  11. Kuzikan
    Kuzikan Bobtail Member
    18
    Jul 20, 2012
    Calgary
    I work for a cat dealer- CAT will NOT cover any resultant damage caused by an aftermarket device- any dealer caught installing it wwil loose their liscence, especially if it involves emissions (3000$ fine for tech, and up to 100000$ for shop) if the dealer is warranting it, it's not a CAT warranty-2 different things. I'm overhauling a brake saved 6NZ and he put on a bullydog non waste gate turbo, manifold and he lost any and all warranty for the $12000 I frame kit he bought, plus as a certified tech I have to report any and all aftermarket changes to cat ( including resistors on fuel and air temp sensors, plugged waste gate lines, etc) warranty is a touchy subject- it may be up to a year after the deale makes the claim and it can be rejected and they come back saying you have a bill to pay.
