Cb problem
Discussion in 'Millis' started by Myoneload, Sep 17, 2013.
It probably only works with the switch on.
I was having issues but it turned out to be my cb. Replaced it and been good since
If you are referring to the external speaker, its tied in with the qualcom at times you have to hit the home button on the qualcom several times to get the external speaker to work for the cb. also depending on how much power your running the dash posts will starve the cb out of required power, if you get the chance have it wired direct to the batteries. also the T700's are know to have a bad ground issue regarding the antennas.
It was the Qualcomm. Took a while for me to figure it out. Thanks for the replies.
