Company does urine AND hair test?
Discussion in 'Questions From New Drivers' started by zoekatya, Apr 18, 2013.
  1. zoekatya
    zoekatya Medium Load Member
    395
    Thanks Received:
    94
    Mar 15, 2013
    I'm about to go to a company orientation and they tell me now that they do both a urine and hair test. Why would they do both? are they bluffing about the hair test part? Thet last company I was with only did urine.
    I know I can pass the urine but the hair i'm not sure about because I took a xanax (anti-anxiety medication) my friend gave me because I was having a panic attack a week and a half ago. If I don't pass will it show up on the DAC or any national drug test DOT thing? Should I shave my whole body?! haha
    mje Thanks this.
  2. amanzanedo
    amanzanedo Light Load Member
    54
    Thanks Received:
    14
    Apr 10, 2013
    Yes do it.
    mje and zoekatya Thank this.
  3. Bayle
    Bayle Road Train Member
    3,061
    Thanks Received:
    1,219
    Aug 30, 2007
    Cottage Grove, MN
    They will just send you home if they can't get hair to test.
    zoekatya, mje and TRKRSHONEY Thank this.
  4. Drac1985
    Drac1985 Medium Load Member
    337
    Thanks Received:
    191
    Apr 4, 2013
    Cleveland , Ohio
    When you say your WHOLE body it had better been everywhere. One guy did the shave routine and neglected the hair on his Johnson. Guess where they took their clipping from..
    mje, pattyj, TRKRSHONEY and 1 other person Thank this.
  5. zoekatya
    395
    Thanks Received:
    94
    Mar 15, 2013
    mje Thanks this.
  6. Drac1985
    337
    Thanks Received:
    191
    Apr 4, 2013
    Cleveland , Ohio
    Good question. I am not sure if they keep a record of those that dont pass. Better let someone esle answer that. Anyone??
  7. Add a truck driving job review
  8. Ridgeline
    4,021
    Thanks Received:
    7,451
    Hair tests show history of drug use and some other drugs as a back up to the pee test. The tox panels they use look for common things.
    IF you take something you are not prescribed, then it is dumb. Sorry but I dealt with too many people doing this and costing me money.
  9. zoekatya
    395
    Thanks Received:
    94
    Mar 15, 2013
    If I don't pass will it show up on the DAC or any national drug test DOT thing? Should I find some other type of work for a bit. I don't want to screw up my record. A lot of company applications ask 'have you ever failed a drug test' if I lied and said no is there any database or record they could check to find out if I lied. Again I am not a drug addict or even a recreational user. I am genuinely concerned about my record.
    mje Thanks this.
  10. ShootThis
    ShootThis Medium Load Member
    606
    Thanks Received:
    775
    Jun 20, 2012
    Wondering Where I AM Again???
    No offense intended but why would you do such a stupid thing knowing you where going to try to get a driving job?
  11. zoekatya
    395
    Thanks Received:
    94
    Mar 15, 2013
    The last company I worked for only did a piss test. I assumed it was the industry standard. I only took one Xanax and didn't know about companies hair testing. I haven't drove for over 8 months. Look I wrote this post because I needed help. Not to be bashed or called stupid people. If you can't answer the question please don't waste my time and yours.
    mje and toostroked Thank this.
  • Draft saved Draft deleted
