Connex 3300hp-zx radio Frequency question
Discussion in 'CB Radio Forum' started by hawkjr9, Oct 28, 2012.
  1. hawkjr9
    hawkjr9 Bobtail Member
    5
    Thanks Received:
    Oct 28, 2012
    I have a Connex 3300hp-zx radio. Does anyone know of any sources or books available on how to use it? Not the owners manual because that tells absolutely nothing. I want to know what the difference between the FM and AM selector is, and what bands the BAND selector works on (D/A E/B F/C selector), and what the BAND HI/LO selector does. Again, my question is not whether this is a legal radio, but does anyone know of any sources or books available on how to use this radio.
  2. BossOutlaw88
    BossOutlaw88 Road Train Member
    1,451
    Thanks Received:
    344
    Oct 30, 2011
    Cali
    Talk to the guy at customcbradios. Com. He knows about that very well.
    hawkjr9 Thanks this.
  3. hawkjr9
    5
    Thanks Received:
    Oct 28, 2012
    Thanks! I will check him out.
  4. Mt Airy
    Mt Airy Light Load Member
    57
    Thanks Received:
    10
    Aug 25, 2012
    I got a Galaxy and I am in the same boat is you with all those buttons and knobs .
  5. hawkjr9
    5
    Thanks Received:
    Oct 28, 2012
    I am still searchin so I will reply with anything I find out.
  6. Mt Airy
    57
    Thanks Received:
    10
    Aug 25, 2012
    I spin the band knob and never hear a thing. some times on the lsb I hear stuff on 38 LSB but they never respond to me .??
  7. hayseed
    hayseed Light Load Member
    188
    Thanks Received:
    84
    Dec 31, 2011
    The Natural State
    Mt. Airy,
    If you are not getting any responses on 38 LSB, you need to have your system looked at and checked. You haven't given any details about your setup. Most any day of the week, you should be able to talk/hear someone on 38 LSB. If not, something may be wrong with your eq.
  8. hawkjr9
    5
    Thanks Received:
    Oct 28, 2012
    My frequency knob has DA, EB, and FC and the radio has a HI and LO band switch. What frequencies are each of these settings?
  9. hawkjr9
    5
    Thanks Received:
    Oct 28, 2012
    My radio has a band knob with D/A, E/B, and F/C and then it has a HI or LO band switch. Does the radio use bands A, B and C with the Band switch on LO and D, E, and F with the Band switch on HI? What frequencies are each of these bands? My red wire has been removed. When you say 38 LSB is that CB channel 38 on lower side band?
  10. mike5511
    mike5511 Road Train Member
    2,410
    Thanks Received:
    849
    May 15, 2011
    NW Arkansas
    here is a band chart. If you are trying to talk on sideband, be sure you have your echo turned off. I have found most of these radios are not properly aligned when they are converted for use on 11 meters. Many times they will make the conversion for 11 meters, fairly simple, and never re-align the receive to 11 meters. These are great radios when properly set up.
    http://www.cbtricks.com/radios/galaxy/dx66v/dx66v_band_chart.htm
  • Draft saved Draft deleted
