Cost to rebuild ISX
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tnovakow, Oct 19, 2010.
  1. tnovakow
    tnovakow Bobtail Member
    25
    Thanks Received:
    Aug 26, 2009
    allen park mi
    How much should one really be paying to have a ISX overhauled? Prices are all over the place, with people paying as much as 19k and as little as 8k. Also what kind of warranty should one expect from the shop doing the overhaul? Anyone recommend a good shop to do the good job at a fair price?
  2. QUALITYTRUCK
    QUALITYTRUCK Medium Load Member
    526
    Thanks Received:
    182
    Jun 14, 2009
    romulus,mi
    sorry to moderator if inappropriate.i am in romulus 10 minutes from you.will give an honest opinion,and a fair price.would not want to get a bad reputation on these message boards.
  3. tnovakow
    25
    Thanks Received:
    Aug 26, 2009
    allen park mi
    Hi, I dont need one right now but pushing 750k and gunna have to start planning for it. I burn about 1 gallon every 10-12k and blow by seems to be increasing little at a time.
    Are you over by the napa on Ecorse?
  4. Heavyd
    Heavyd Road Train Member
    4,238
    Thanks Received:
    1,868
    Feb 4, 2009
    The main reason for the wide range in prices is the parts you choose to replace or not. Believe it or not, but some consider an engine overhauled when reusing the original head and injectors. Pistons and liners only is a cheapy rebuild. If want to go all out you are looking at replacing the head/turbo/water pump/injectors/bearings and of course, pistons and liners. Obviously, the more parts you replace the more costly the rebuild will be.
  5. QUALITYTRUCK
    526
    Thanks Received:
    182
    Jun 14, 2009
    romulus,mi
    i am in the truck stop on corner of ecorse and inkster.ask for Ray.i am the owner.
  • Draft saved Draft deleted
