cruise control problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tubbs8863, Jan 14, 2010.
  1. tubbs8863
    tubbs8863 Bobtail Member
    Thanks Received:
    Jul 10, 2008
    hodge la.
    99western star 500hp 60 series detroit. cruise works fine when stoped and parking brakes applied.when i set it at hwy speeds computer says cruise set at 65 or whaterver i set it at but when i lift off the pedal it's notworking can anyone help
  2. Hardlyevr
    Hardlyevr Road Train Member
    3,226
    Thanks Received:
    2,439
    Jul 30, 2009
    Gardners,PA
    setting the parking brake and using the cruise to bring up the idle speed, does the cruise come off if you step on the brakes or pull the trailer arm? The micro switches in either of those spots could be open and won't let you use the cruise when the parking brake is off.
  3. tubbs8863
    Thanks Received:
    Jul 10, 2008
    hodge la.
    thanks hardlyeve the cruise does not go off when i hit brakes. could you desribe the micro switches where to locate them
  4. heavyhaulerss
    3,513
    Thanks Received:
    1,781
    Dec 23, 2009
    AL/TN BORDER
    It has been 8 years since I had the same problem, with my det. I remember there being 2 switch/relays behind dash, behind the cruise control switch. they both affect the cruise. I replaced both of them. it fixed the problem. that was with a 11.1 ser 60. I cannot remember what they looked like. I do remember straight wiring one to a toggle switch to see witch one it was. I found out witch one it was but, decided to get both cause I figure if one went out, the other aint too far behind.
    tubbs8863 Thanks this.
  • Draft saved Draft deleted
