cummins N14 redhead with low oil preasure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by salidaco, May 16, 2012.
  1. salidaco
    salidaco Bobtail Member
    10
    Thanks Received:
    11
    Jan 24, 2012
    salida, co
    Hello, I recentely purchassed a 1999 Volvo with an N14. Since I've owned it the oil preasure only shows 30lbs. Occasionally a engine fluid warning light comes on and cut's out the engine intermitenly. Yesterday It did it 6 times on the way home and on idle the oil preasure was under 10lbs. So obviously it's time to resolve the issue. From Idle, when I give it throttle the preasure goes back up to 30lbs so I'm thinking it's the oil pump. But an oil pump is $700 so I want to make sure that's it and not a sensor or something. The engine has 970,500 on it. Any input would be greatly appreaciated
  2. bender
    bender Road Train Member
    2,105
    Thanks Received:
    1,293
    Jul 20, 2010
    Don't Kid Yourself
    Check oil pressure with a manual gage at point of sensor. Verify correct idle speed. Replace lube filter. What engine oil are you using and how is the condition of the oil. What is your oil temp gage showing? Coolant temp? If manual gage matches sensor/truck gage values check bearings and oil pump.
  3. marmonman
    marmonman Road Train Member
    1,196
    Thanks Received:
    1,971
    Dec 14, 2009
    central illinois
    Sounds like it is time for rods and mains at the very least .
  4. salidaco
    10
    Thanks Received:
    11
    Jan 24, 2012
    salida, co
    I have been sing Mobile 1 Delo 15 40. I sent an oil sample off and it came back normal. The Temps are also normal. I will start with a manual sensor to see. Thanks for the info:biggrin_255:
    bender Thanks this.
  5. bender
    2,105
    Thanks Received:
    1,293
    Jul 20, 2010
    Don't Kid Yourself
    It would also be a good idea verify fault codes to be sure that's what's causing the check lamp and derate.
  6. Smellfunny
    Smellfunny Medium Load Member
    594
    Thanks Received:
    161
    Jan 28, 2012
    South Carolina
    I agree. If it has not been done it is time for them to be done.
  7. Add a truck driving job review
  8. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    Thanks Received:
    35
    Sep 2, 2009
    I would also check the cam bearings too
  9. osokusmc
    osokusmc Light Load Member
    259
    Thanks Received:
    8,422
    Feb 22, 2011
    SD
    Mine was the oil pump. It would alarm at low idle but not high idle and shut down whenever it felt like it. It would flash a shutdown sequence driving, at around thirty psi, but not always shutdown. Time before last was just a sensor.
  10. Autocar
    Autocar Road Train Member
    3,167
    Thanks Received:
    2,314
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    The cam doesn't get close to the wear as the rods and mains do.
  11. timc1134
    timc1134 Light Load Member
    106
    Thanks Received:
    26
    Dec 21, 2012
    South east, Idaho
    30 psi is not low for a N14 standard is 32 psi@ 1200 rpm with fresh oil above 7 psi at idle and shut down below 3 psi. N14 are low pressure high volume engines. whats the mileage on your engine/ oil pump.
  • Draft saved Draft deleted
