i have volvo d13 2014 while in iowa truck started shaking pulled to the mechanic he told my 6 injector is bad turbo bad and egr cooler leaking and gonna cost around 12k after opening injectors he said rockers need to replaced another 2k expense and my volvo is 44000 miles after fixing everything mechanic say problem is still same need to open head need to dig deep.
d13 xe volvo 455 hp 2014 engine got overhauled at 440000 miles
Discussion in 'Volvo Forum' started by gurdev, Sep 24, 2016.
And I am not sure what the question is? Can you unpack it and make it clearer. What kind of shaking and when did it occur? Are you saying you have already had the work done and now another mechanic says you need to have more work done? Where did you have the previous work done if you did and is this new mechanic a second opinion?
Did you contact volvo help line to find out what the codes were for? Did the mechanic do a pressure test to find out if the injectors were leaking or something else is? Did you have an oil test done to see if coolant or fuel was mixing with the oil and if there were any other contaminants. Overnite if you must it is worth the cost. Do you trust this mechanic? Have you lost coolant or oil? I am not an expert, not even close but gather some more information and hopefully others can help out.
ya contacted Volvo help line they interpreted the codes. mechanic did the pressure test too oil test was not done, coolant was getting low but that was due to leaking egr. so far mechanic is trustworthy BUT YOU NEVER KNOW.
Sometimes if you shake it the treat comes out ...
Hahaha
I use to have similar problem.Was shaking between 60-65.change all injectors and cups problem solve.
KB3MMX Thanks this.
