Can anyone comment on what would be needed to convert both axles to disc brakes?
Would it be easier to just switch out the whole axle or just brakes?
It costs a lot to do on the tractor, so I am considering just the trailer.
Thanks
DISC BRAKE TRAILER RETROFIT ??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by areelius, Feb 6, 2016.
Page 1 of 4
You'll need other axles for sure. A caliper wouldn't fit on a bracket where a brakechamber usually sits. Hubs will be different.
Brake valves should be the same. You might need different hoses.
I never did some research. But that's what comes to mind.
Switching the entire bogies might be the easiest way.areelius Thanks this. -
About 15 months ago when shopping for a new trailer it was a $2,500 upgrade option over drums. So to spec is relatively cheap, worth it, and will get your money back in reduced maintenence costs. But I'm betting to convert existing drums you will find it cost prohibitive just like with the tractor.
What is the advantage of discs other than better stopping powers?
What is the cost for parts alone to convert a tractor? -
My understanding was that current disc brakes do not in fact decrease stopping distance better than drums. The benefit on a trailer was the fact that the only grease fittings on a disc brake equipped unit were to lubricate the landing gear. And pads last a lot longer than shoes plus are cheaper and quicker to replace.
One big advantage is that scale inspectors don't have much to find wrong and just about skip past them when inspecting. No free-play, cracked drums, or uneven wear. Most of the time wasted on inspections is helping the officer do a free-play assessment on all air chambers. With discs there is no free play to look at.
For me its about safety too. I need to be able to keep from running over all the 4 wheelers who pull in front of us and then hit their brakes. Its a great feeling when you need discs in a panic. -
Page 1 of 4
