Dissable daytime running lights
Discussion in 'Freightliner Forum' started by Roadrunner007, Feb 27, 2013.
  1. Roadrunner007
    Roadrunner007 Bobtail Member
    9
    Thanks Received:
    Feb 27, 2013
    Is there a way to disable the DRL. Without going in the ECM.
  2. kerosene jockey
    kerosene jockey Light Load Member
    99
    Thanks Received:
    88
    Jan 31, 2013
    Just curious as to why you would want to ?
  3. Calspring
    Calspring Light Load Member
    290
    Thanks Received:
    143
    Jun 22, 2012
    Canada
    A hammer will work.
    But in all seriousness why are you wanting to disable them. They have been proven to reduce crashes by about 10%.
  4. Mattress Monkey
    Mattress Monkey Medium Load Member
    302
    Thanks Received:
    100
    Feb 1, 2013
    Are they required in canada? Seems as though every canuck has em on..
  5. Calspring
    290
    Thanks Received:
    143
    Jun 22, 2012
    Canada
    Since 1990 they have been required on all new vehicles purchased. I believe if you import one to Canada you need to have it enabled as well.
  6. Roadrunner007
    9
    Thanks Received:
    Feb 27, 2013
    1.) My truck is white and Kawasaki green. If they can't see me, two lights ain't gonna help.
    1.) I just don't like them on and want them off
    3.) my manifold switches or ECM is having issues and now they stay on even when parked
    its on a '99 Century
  7. Add a truck driving job review
  8. Roadrunner007
    9
    Thanks Received:
    Feb 27, 2013
    They're not on big good Pete's or W900 so I don't believe they are required. As for Canada
    this truck will never see that side of the border as long as I own it.
  9. Pedigreed Bulldog
    3,827
    Thanks Received:
    4,731
    May 7, 2011
    I won't buy a vehicle with daytime running lights. Unless it's raining or foggy, as soon as the sun is up, lights go off until the sun goes down again. I can't bring myself to believe that people can't see an 8.5' wide, 13.5' tall truck coming at them, but rather that their impatience gets the better of them and they'd rather take their chances getting hit than be "stuck" behind a "slow" truck.
    Besides that, I ride a motorcycle. Motorcycles are required to burn their headlights 24/7 so that they stand out in traffic. If every knucklehead driving a car or truck has their headlights on, motorcycles blend in again and become harder to pick out in traffic.
    Daytime running lights ought to be illegal for anything with 4 or more wheels.
    EZ Money Thanks this.
  10. Colorato
    Colorato Road Train Member
    1,239
    Thanks Received:
    669
    Feb 22, 2011
    There's a relay somewhere. Find it and remove it.
    I liked them on my 06. At night when I flashed drivers over my headlights would go off and the DTR would come on. They weren't my brights so it worked for everyone.
  11. Cowpie1
    Cowpie1 Road Train Member
    4,802
    Thanks Received:
    3,641
    Nov 25, 2008
    Kellogg, IA
    Every truck I have ever been around that had daytime running lights had a fuse in the fuse relay that you could remove to disable the DRL. Did not affect the regular lights. I drove a '96 T600 that had daytime lights, and my '06 International had them. I just pulled the fuse and disabled it.As for the question "why would you want to?" One reason is so that you are not distracting a person trying to back into a dock while you are moving thru a lot. There are other reasons.
  • Draft saved Draft deleted
