I've been reading about the new scanners some DOT stations will use to determine if our brakes are working properly.
What infractions are being wrote up using this data, can the truck trailer be put out of service?
This is technology that my service center doesn't have. I haven't seen these machines yet, I don't want to either.
I don't mind the DOT helping me prevent a problem. BUT I'm mad as heck if they use my taxes to generate a way to fine me or put me out of service using technology I can't afford to acquire or pay to use.
DOT brake scanners.
Discussion in 'Experienced Truckers' Advice' started by xsetra, Aug 30, 2015.
Page 1 of 4
Are these the heat scanners?
It's all infrared. They basically look to see if one axle end is significantly hotter or cooler than the rest. It takes further inspection to determine the cause, and if it is a violation.
Mother Trucking Princess, Studebaker Hawk and HorseShoe Thank this. -
Not sure what they are. I read they can accurately test the performance of each braking position. The DOT will have these at 18 inspection stations this year for the brake check week. Not sure which states or stations. Thanks to funds provided by CVSA.
never heard of them, doing that, but who knows..??? all i can think of is the portable hand held infra red scanners that take temperature readings.
or at the very least, thermal imagers....
Mother Trucking Princess Thanks this. -
Yep, unless you have a wheel bearing start to go bad.
Big Don Thanks this. -
lights work..?? check
trailer loaded?? check
lunch with me.?? check
but then too, all our equipment is brand new..
told ya, i hate to say it......
and then too, we run at night, never an open scale house.....
been going on 4 years now......never open. -
i http://www.cvsa.org/programs/op_airbrake_brake_systems.php#pbbt_1
What is a PBBT inspection?
A Performance Based Brake Tester (PBBT) measures the slow speed brake force and weight at each wheel, adds up the total vehicle brake force, and divides it by the total vehicle weight to determine overall vehicle braking efficiency. U.S. federal regulations and the North American Standard Out-of-Service Criteria require a minimum braking efficiency of 43.5%. If your vehicle’s braking efficiency is below 43.5%, your brakes are in need of service because they are not providing the minimum stopping power required and are performing poorly.
Click here for an example of what an inspection report will show if you are tested on a PBBT. Note that if any wheel end is showing braking efficiency below 43.5%, there’s likely something wrong with that brake, even if no violation is found.baha Thanks this. -
i get an error to your link
Page 1 of 4
