Hello, I'm not too familiar with the Eaton smart shift auto 10 speed transmissions, but how do you set the truck to start in second gear instead of first gear? The truck starts in first gear, but it holds the rpm around 2200 for several seconds before it shifts into second gear. Is there anyway to stop it from holding in first gear at a high rpm for several seconds? This is the 2 pedal transmission.
Thank you!
eaton auto question
Discussion in 'Freightliner Forum' started by 4vmach1, Jul 21, 2016.
It has to be done through Eaton service ranger program on laptop.
4vmach1 Thanks this. -
Service ranger software is used to set the default starting gear/max starting gear, ect.
It's not letting me configure or change anything with my software when I click to change the starting gear and shift point.
It's been a while since I've changed it. You're a tech so call Eaton (maybe get an answer after a half hour on hold)?
What version of serviceranger is that? -
Its missing that thing you rest your right hand on
