Eaton Ultrashift on Volvo problem
Discussion in 'Volvo Forum' started by Ruta55, Oct 14, 2016.
  1. Ruta55
    Ruta55 Bobtail Member
    19
    Schaumburg,IL
    Hello, i have a '07 volvo with eaton ultrashift 10sp, few days ago driving uphill with light load @65mph service light on shifter started to flash and a display on cluster started to blink F. At that point for a second engine lost a power and went back to normal again. When i stopped and pulled out code it was MID 130 PID 59 FMI 7 or Shifter finger gear position , computer recorded this 5 times. Next day flat road @70mph, flashing both lights and nothing, but when was slowing down and tranny was making reduction to 9th i got a slam/hit as tranny was trying to put 9th too fast for a truck speed, few seconds - back to normal. Made to home already with no issues. Does anyone any ideas what is that could be?
  3. nasriza
    nasriza Road Train Member
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    probably XY Shifter
    flood, KB3MMX and Socal Xpress Thank this.
  4. Ruta55
    19
    Schaumburg,IL
    Well, had that replaced two years ago and now again? That's crazy, parts nowadays not reliable at all?
  5. KB3MMX
    KB3MMX Road Train Member
    3,057
    2,573
    Dec 29, 2014
    Orrstown, PA
    Long time problematic part of the Eaton transmission..
  6. Ruta55
    19
    Schaumburg,IL
    Well the problem is code went to inactive and wont came up again. What i currently did - bought a new one to keep with me and took out current one to inspect. As code was referring to mechanical failure - nothing found...
  7. nasriza
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    you wont see anything mechanicaly good chance the position sensors acting up or maybe a motor got stuck for a little bit better change it and avoid the costly repair on the road.
  8. flood
    flood Road Train Member
    4,021
    3,754
    Dec 25, 2010
    if you don't drain your air tanks every day you can get water into the shifter
    KB3MMX Thanks this.
  9. nasriza
    2,368
    2,039
    Feb 1, 2013
    Chicago, IL
    this would be true for i shift and zf not eaton being that shifter is electrical
    KB3MMX Thanks this.
  10. KB3MMX
    3,057
    2,573
    Dec 29, 2014
    Orrstown, PA
    Should I see water coming out?
    I haven't been able to get any in my new truck
  11. Charles 780 RV hawler
    Charles 780 RV hawler Bobtail Member
    6
