1239 Accelerator Pedal or Lever Position Sensor 2 Circuit - Voltage Above Normal, or Shorted to High Source
what is this and how can I fix it?
thanks in advance
fault code 1239 Acc Pedal or Lever Position Sensor 2 Circuit - 05 Int ISX 400 cummins
Discussion in 'International Forum' started by hd99_fatboy, Mar 1, 2014.
Double check the model year, this engine should be a CM871 if it is generating that code. CM870 were still around in 05 and had different throttle pedal wiring. For the 871 model, the throttle pedal has actually two separate position sensors in it. #1 and #2. #2 is always exactly 1/2 the voltage signal of #1 so the ECM can verify it is getting a valid signal. The signal return is higher than normal. This is normally a shorted pedal position sensor. If you unplug it you should get 1241 active. If you do, replace the pedal sensor.
QUALITYTRUCK Thanks this. -
I see the harness under the pedal, is that where the sensor is, or is it somewhere else? do I have to remove the pedal to unplug the sensor? 3 or 4 bolts holding pedal to floorboard...
How you been HeavyD? -
I am getting real sick of this cold weather! Mosquitoes and humidity any time now!!! The sensor is part of pedal, two small screws hold it on. I can't remember if the plug is right at the sensor at the pedal, or if the sensor has the harness attached to it, and the plug in hiding up inside the kick panel. It is tight down there, but if the connector is at the sensor you should be able to unplug it there.
I hear that bro, been a hell of a winter, and your up north right?
I'll dig into this pedal a lil more and let you know how I make out. been sidetracked with other auto issues, a 93 bmw 325 and a 93 honda accord, both daily drivers for my wife and kid. long cold afternoon on my back in the driveway...Heavyd Thanks this. -
@Heavyd ....please help with 2011 prostar shut down coz accerelator pedal sensor fault. i replaced new pedal but still getting alarm code. thanks
Do you have the actual fault code number?
