fault codes o8 isx
Discussion in 'Volvo Forum' started by timetravel1, Sep 9, 2012.
  1. timetravel1
    timetravel1 Bobtail Member
    Thanks Received:
    Mar 2, 2012
    sanbernardino ca
    ineed to know what the fault codes fmi128 pid 101 fmi 4 also i have crank case pressure fault changed the filter but the ckeck engine fault stills goes on and off i have a 08 isx
  2. dloving8915
    dloving8915 Light Load Member
    211
    Thanks Received:
    68
    Sep 18, 2010
    Dallas, Texas
    I had a crankcase pressure go off on my cummins Changed the filter as well still coded. Found the tube that vents out of the filter box plugged up!
  • Draft saved Draft deleted
