fifth wheel position
Discussion in 'Trucks [ Eighteen Wheelers ]' started by venodaren, Jan 4, 2013.
  1. venodaren
    venodaren Bobtail Member
    46
    Thanks Received:
    Dec 1, 2012
    Malaysia
    hello..
    i have problem in adjusting fifth wheel..i dont know how to locate the correct position for fifth wheel
    my wheel base is 3975 and for another truck is 2900 all in mm..
  2. ralph
    ralph Road Train Member
    1,118
    Thanks Received:
    626
    Mar 1, 2009
    At The Key Board
    Center of the drive axles is always a good place to start.
    How many kg's are you allowed on a steer axle in Malasyia?
    SHC Thanks this.
  3. venodaren
    46
    Thanks Received:
    Dec 1, 2012
    Malaysia
    im not sure about the allowable weight...but wrong position of my fifth wheel causing my new tires worn out in 1 month...the tires looks like drift tires.lolz..pls help me!!
  4. daf105paccar
    2,319
    Thanks Received:
    1,171
    Apr 15, 2012
    Venodaren,can you post a picture off your truck?
    So we get an idea off how you are setup.
  5. claytonr1973
    claytonr1973 Light Load Member
    249
    Thanks Received:
    266
    Jun 1, 2008
    miami,ok
    You said they look like drift tires. Do they have scrub marks on the tread? Sounds like axle lock might be stuck or axles out alignment.
  6. venodaren
    46
    Thanks Received:
    Dec 1, 2012
    Malaysia
  • Draft saved Draft deleted
