Found blower motor resistor location 06 t800
Discussion in 'Kenworth Forum' started by Wingnut27, Jun 9, 2016.
  1. Wingnut27
    Wingnut27 Bobtail Member
    May 28, 2016
    Blower motor resistor in kenworth t800 is located inside cab to the left of glove box. If you pull the 2 screws holding switch plate and look to the right front corner and down you can see the top screw of resistor. Had a Heck of a time finding it.
    wrongwaytommy Thanks this.
  3. Lococa
    Lococa Bobtail Member
    Apr 10, 2019
    Hello fellow truck drivers I found the location of the a/c resistor on a 1997 kw t800,open the passenger side door and it’s mounted on the right side of the glove box with two 8mm screws and a 3 way plug hooked up to it
    QUALITYTRUCK Thanks this.
  4. Drifter28
    Drifter28 Bobtail Member
    1999 t800 just changed out my blower motor and resistor .ac worked perfect before after replacing all that ac will not kick in . Any Info
  5. canosoup
    canosoup Bobtail Member
    I found it somewhere else on my 05 Kenworth T800. Posted a video of location for ya...
