####, out of my 19 trucks 5 had all brakes frozen... All of them 2016 cascadia.
It did rain and its now -2 celcius but come on... Only the Cascadia froze. I hope its not à bad back plate design or a common problem.
Frozen brakes
Discussion in 'Ask An Owner Operator' started by skro47, Nov 30, 2015.
Page 1 of 3
tech10171968, Rock 'n Roll Relocater and Straight Stacks Thank this.
I know it takes 2 mins. Did the hammer thing. They are supposed to purhe tanks but pads were frozen to the drums, not frozen air liens or tank. There was ice everywere inside the drums.
Trucks did not move while it was raoning last night. And I only had troubles with one particular truck model. -
Rock 'n Roll Relocater Thanks this.
Haha had my first winter welcome 5 years ago. Used to it... Simply hoping it wont happen all the time you know... 5 out of 5 froze...
Talking about campers... We had one about 5 weeka ago with 5times premited propane tanks catch fire in the tunnel going in Montréal. Closed for about 12 hours.Fajo Thanks this. -
Sometimes helps to gently rock the truck in reverse a couple times to break the shoes free of the drum. Usually works.
Dave_in_AZ and 25(2)+2 Thank this. -
COURSE, if I'm hooked to a loaded trailer. I'll lower the landing gear and drop the suspension so i'm not pulling the weight of the load. -
I wonder if your Cascadia where parked at a different angle then your other trucks?
Normally if my brakes freeze I can just pump my brakes for a bit. It will usually break free. -
I just cuss, get the hammer out, and go to work. Then when I get back in the truck I look at all the trucks leaving that have one or more wheels frozen just dragging their wagon not a clue.
tucker Thanks this. -
If i can drag to asphalt. i'll take that over freezeing my arse off, laying in the snow, trying to free em up.
Now, if drivers are dragging down 25 miles of asphalt, still locked up. Then i'd be doing something, ( probably not pretty either ).
If i'm stuck, then it sucks.skro47 Thanks this.
Page 1 of 3
