fuel filter heater
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Nov 17, 2011.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    109
    Thanks Received:
    5
    May 3, 2011
    Des Moines, IA
    Hi, i was wondering how would I go about keeping my fuel filter warm, when truck is off, since I have one of those see through fuel filter housings. I was on wolverine site and they have heater pads, but it only shows them on metal fuel filters.If someone knows solution pls post it. Thx
  2. Pfuse
    Pfuse Light Load Member
    119
    Thanks Received:
    50
    Aug 18, 2006
    La Crosse, WI
    Are you sure that your filter base isn't heated? My Davco has coolant lines running through the base and a spot to plug it in if necessary. It doesn't take very much time at all before warm coolant gets into the base.
  3. gerardo1961
    gerardo1961 Road Train Member
    1,300
    Thanks Received:
    189
    Feb 21, 2010
    miami
    my davco 382 is the same without heater i was talking with the shop and a guy tell me when i like a haeter i have to buy a new davco 382 with heater
  4. Flightline
    Flightline Road Train Member
    2,282
    Thanks Received:
    983
    Oct 1, 2011
    Almost There
    If yours has the heat lines, it should have room for a heater also, If so, just need to replace one of the plugs in the bottom with a heater. Some are 120 volt and some are 12 volt. Oh, you will need to run a power to it from a switch if running on 12 volt.
  5. ColumbiaBoB
    109
    Thanks Received:
    5
    May 3, 2011
    Des Moines, IA
    I will take a closer look over the weekend.
  6. heavyhaulerss
    3,303
    Thanks Received:
    1,582
    Dec 23, 2009
    AL/TN BORDER
    I have the preheater on my davco. though it is on only if key is on. you can turn key on & it will take just a few minutes to warm fuel. but it does nothing while key is off. another thing is, if truck is off & the fuel in the tanks gel, then the preheater wont help that.
  7. Add a truck driving job review
  8. Flightline
    2,282
    Thanks Received:
    983
    Oct 1, 2011
    Almost There
    Gelling is very unlikely anymore. Since most truckstops mix #1 with the #2 fuel this time of the year. And gelling doesn't start normally until below 15 degress. The futher north you run the sooner and more the truck stops mix this fuel to prevent it from gelling at the pump. A rare way to get geling would be running up north on fuel you purchased down south.
    Also this mixing of fuel is the big reason we all get worse fuel economy in the winter.
    Pfuse Thanks this.
  9. Cowpie1
    Cowpie1 Road Train Member
    4,673
    Thanks Received:
    3,517
    Nov 25, 2008
    Kellogg, IA
    Flightline is right. I would add though, that one of the biggest problems is condensation in fuel tanks. Icing is probably the culprit more times than fuel gelling. The best way to reduce that risk is to top the tanks when possible before a time when the truck will be shut off for longer than a couple of hours. When fuel cools, it contracts and tanks that are not close to full will pull in a lot of moist air when that fuel contracts. Over time, water builds up in the tanks. Then you might have to reach for that Power Service 911 stuff and change out those filters. Not a good thing when the temp is below 0F and the wind is blowing at 30 mph. I try to top off the tanks each day during the real cold times. Not always practical, I will concede that. But the more you adhere to doing it, the better off you will be. An added plus to keeping tanks as full as possible.... it takes a lot longer for the warm fuel in a fairly full tank to cool than in a tank half full or less.
    And, as anyone at this game for any length of time will tell you, even the fuel islands at the truck stops can freeze up. If you keep your tanks as full as possible as often as you can, if you come across one of those truck stops that you can't get fuel at, you will not be left out in the cold. Pardon the pun.
    Flightline Thanks this.
  10. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    Thanks Received:
    106
    Oct 17, 2009
    Jones,Oklahoma
    You should really do some research on the ULSD that is being sold nowadays. You might think twice before you say that about fuel gelling.
    http://www.enertechlabs.com/ULSD_Cold_Weather_Information_09032007.htm
    Flightline, heavyhaulerss and Cowpie1 Thank this.
  11. Flightline
    2,282
    Thanks Received:
    983
    Oct 1, 2011
    Almost There
    Very Interesting and worth reading. Though I don't see it disagreeing with my comments but adding alot more.
    Fuel iceing and wax removing from the fuel around 0 degrees. But also stated non of the antiwaxing additives would help this problem.
    I think Cowpie has the best solution (keeping the tanks top off).
    I would like to point out that I haven't used any antigel additive in the last 10 years and have not had fuel gel in last 15 years. Also I try to stay south of Canada.
    Cowpie1 Thanks this.
  • Draft saved Draft deleted
