fuel gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, May 28, 2009.
  1. gafred99
    gafred99 Light Load Member
    119
    Thanks Received:
    May 28, 2009
    Tignall
    Fuel gauge on a 97 FLD120 bounces all over the place, I have cleaned the ground on fuel level sender. Any other suggestions to fix before I sink a lot of $ for guessing?
  2. MedicineMan
    MedicineMan Road Train Member
    5,792
    Thanks Received:
    6,408
    Jan 13, 2007
    Woodville, TX
    its the sending unit in the tank. its a long arm that pivots in the middle and that pivot point wears out causing the eradic reading
  3. gafred99
    119
    Thanks Received:
    May 28, 2009
    Tignall
    good suggestion, it does it while driving and sitting still and idleing.
    bounces like a yoyo...
  4. MedicineMan
    5,792
    Thanks Received:
    6,408
    Jan 13, 2007
    Woodville, TX
    ya, it's the pivot point. it gets loose. take it out and look at it, you'll see what I mean. it floats on one end so when the pivot goes out it flos not only up n down but side to side. so you don't need to be moving.
    take it out, if it's not all floppy then look somewhere else. $90 each for my peterbilt. others will probably be cheaper because you dont have the glory of buying them from a pete dealer
  5. Les2
    Les2 Road Train Member
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    kicked back in my lazyboy...
    If you have the full skirts, thats gonna be the biggest PIA of taking it all apart to fix.
  6. peterod
    peterod Light Load Member
    52
    Thanks Received:
    Jun 8, 2009
    thanks for the info because my guage dont move now i know where to look first
  7. Add a truck driving job review
  8. Scarecrow03
    Scarecrow03 Road Train Member
    3,390
    Thanks Received:
    7,420
    Sep 27, 2006
    In Your Head
    My gauge is off by quite a bit. I've got two 110 gal tanks and the most I've ever put on is about 180 gallons. I only get that much on after running on E for a hundred miles or so. Typically I'm putting between 160 and 170 gallons on. How might I fix this little problem?
  • Draft saved Draft deleted
